It is currently Sun Jun 07, 2026 2:26 pm
PostPosted: Sun Feb 29, 2004 12:46 am
well i was drivin around on deliveries tonight and my truck starts to make a sound when im accelerating. So i think about it for a bit and it seems to resemble the sound you get when you turn on your garbage disposal...not good...just not as loud as that, well at least not from inside the cab. It only makes the noise when accelerating. I can sit and rev the engine into high rpms and no such noise just healthy engine sounds...i can sit with the break on and put a bit of a load on the engine by letting out the clutch some and still the sound isnt there but when i start to accelerate it makes noise....tranny maybe? Any ideas?
PostPosted: Sun Feb 29, 2004 2:18 am
Throw out bearing? :cry:
PostPosted: Sun Feb 29, 2004 2:22 am
check the pipe that comes out of the back of the exsaust manifold. Mine blew out and just before it did it made a sound kinda like your describing.
PostPosted: Mon Mar 01, 2004 5:41 am
it cud be you drive shaft, it does the same thing on my dads car, i duno how to fix it tho, i think ya need to lift it sum how
PostPosted: Mon Mar 01, 2004 3:32 pm
i was told u joints???
PostPosted: Mon Mar 01, 2004 3:37 pm
U-joints could be a possibility, but all U-joints i have experienced made a "clicking" sound before a "garbage disposal growl" Just go under your truck and see if you can twist the drive shaft either way. If theres visual movement, then i would start with replacing the U-joint(s) and go from there
PostPosted: Mon Mar 01, 2004 3:42 pm
come to think of it it does make a click when im just starting off...
come to think of it it does make a click when im just starting off...kind of a TINK! sound...
PostPosted: Mon Mar 01, 2004 8:52 pm
a tink is a u joint, could be making the disposal noise. if not, maybe tranny :cry: its not a throwout bearing it would only make noise when your foot is on the clutch.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Mon Mar 01, 2004 9:27 pm
Yeah im pretty sure you U-joint is going. Oh well, better then the tranny going or something much more expensive! :D
PostPosted: Mon Mar 01, 2004 11:43 pm
yup swap out the U-joints and see how that goes :D
PostPosted: Tue Mar 02, 2004 2:28 am
well i'll just try that then! Thx for the input guys!
PostPosted: Tue Mar 02, 2004 2:52 am
no probs, glad to help
PostPosted: Tue Mar 02, 2004 4:18 am
I hope the U-joint thing is right, but I have another suggestion that might not be so straigtforward...
I was driving to school one day and noticed that when I would let go of the gas I would hear a rough whine coming from underneath. When I got back on the gas it would kind of clunk once but the whine went away. To make a long story short, it ended up being my rearend. I don't know much about rears, so I had a guy do it for me. He said that the pinion had come loose and a couple bearings were worn, so the pinion was kind of moving around when it was "disengaged" (i.e. when I let off the gas) but then would re-engage when I hit the gas so it didn't make that noise.
According to him, that can happen in the opposite too (noise on gas, but not when you're off of it). If you're going to be under there checking your U-joints anyway, give the driveshaft a couple of good tugs. If you can move it around, especially from side to side, you may have some rear end issues that need to be addressed. Bad U-joints will usually cause rough driving whether or not you're on the gas since they're always turning, so I don't think thats what it is, but thats just my 2 cents.
PostPosted: Tue Mar 02, 2004 11:01 am
thank you beetlevh!!! You described my problem since i have had the truck PERFECTLY! Guess i'll see if thats it and be on my way to finding myself a lockin diff.... (-:
 Post subject: u-joints
PostPosted: Wed Mar 03, 2004 6:41 pm
Usually if it is youyr u-joints or your driveshaft the truck will vibrate
PostPosted: Wed Mar 03, 2004 8:55 pm
took off the driveshaft today...what a mess. The rear of the rear u joint not so bad...the front rear u joint another story. Most all the pin bearing things were completely missing because casing has cracked and they fell out...so now that piece that is 1/2 the u joint which slides into the rear of the tranny is cracking apart and breaking...i think this has happened partially because of the play in the worn out parts of the rest of the drivetrain and partially because the ujoints should have been redone LONG AGO...as well as greased LONG AGO...so, that said...anybody have an extra one of these lil things layin around? Mine seems to be pretty busted up and I think when i put it back together im going to end up just having to tear it back apart and put a new/used piece on it...
PostPosted: Wed Mar 03, 2004 10:51 pm
u say the u joint is all busted up and cracked or the housing? the u joint comes out of that housing with the caps.
PostPosted: Wed Mar 03, 2004 11:41 pm
the housing is all busted up...sorry didnt really specify
