It is currently Sun Jun 07, 2026 8:14 pm
 Post subject: Parking Break?!
PostPosted: Fri Jan 30, 2004 3:39 pm
I went to ajust my parking break and the key that locks the ratchet on the parking break shaft is warn out. And will no longer hold the break in place. I need to replace the key or regrind it, but am unable to get it the key out. Any suggestions?
PostPosted: Fri Jan 30, 2004 10:40 pm
OG Lifer
I suggest salvage yards. If you go to grinding on it, you may or may not get the brake to release. If you can find a complete unit in good working order, then I would replace the whole thing.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Fri Jan 30, 2004 11:53 pm
Grimace you musta read my mind...
Resident lurker
PostPosted: Sat Jan 31, 2004 8:05 am
OG Lifer
Hehe. great minds....
PostPosted: Sat Jan 31, 2004 11:38 am
i had this happen to me aswell. I took and bent the lever a bit so that it will engage and everything. Youll have to pull the tire and cover off to do this. But if you can i would pull it off another truck thatrs not worn out.
