It is currently Sun Jun 07, 2026 8:15 pm
 Post subject: problem emailed to me
PostPosted: Wed Jan 21, 2004 1:53 pm
--- "Stanton, Lisa" <Lisa.Stanton@sunmed.com> wrote:
> I sure hope someone can help me out here.
> I got a 1980 Luv, it's a 4cyl, 2bbl. Was running
> fantastic as usaul when all
> of sudden it starts to act like it's starving for
> fuel or air or something.
> Now keep in mind that I've been around cars all my
> life(35yrs)so I now how
> the work.
> I checked everything,, the fuel filter, replaced the
> wires, the coil, the
> rotor, the cap, the points, and it came down to
> thinking that the carb is
> justs worn and adjusted out.
> Go to pick-a-part, found another one, from a 79, put
> in on, ran great in the
> hood, then started doing the same crap that it did
> from the get go.
> Soon as it gets warmed up it acts like its starved
> for gas or air or god I'm
> starting to pull my freakin air out.
> Could it be the ignition switch, could I of got
> another bunk carb.How about
> the regulator?
> PLEASE, CAN YA HELP A CHEVY GIRL OUT HERE?
03Cobra
PostPosted: Wed Jan 21, 2004 1:55 pm
didn't someone say something about a high speed air sensor or something on these carbs?
03Cobra
OG Lifer
Could be the coil breaking down after it gets warmed up and not delivering a good enough spark.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Wed Jan 21, 2004 5:38 pm
Fuel pump wasn't mentioned, and the symptoms sound similar to a low flowing fuel pump. I've had a few of them go, and it sounds similar. You can cruise around all day if you keep the RPM low enough, but go through the gears accelerating up to highway speed and it dies like you shut off the key about the 3-4 shift.
It also could be a vac leak somewhere like perhaps the EGR valve. There is a thermo control vac switch right near the thermostat with hoses going in and out to the EGR valve and to the carb. Since that switch opens up after the truck warms, that would explain the timing of things. There is another thermo control switch in the air cleaner that worth checking out as well.
PostPosted: Wed Jan 21, 2004 7:53 pm
but the stuff 800xl mentioned will only be a CA vehicle. My 80 isnt CA and only has the air pump for emissions. But i would agree that the coil and fuel pump could be the culprit. I would also make shure the points clean, spray some electric contarc cleaner and run a lint free cloth between em and regap em and all that jazz.
PostPosted: Wed Jan 21, 2004 9:28 pm
it sounds like what mine was doing when i first got it. i would be driving down the highway and gradually it would loose more and more power. i thought fuel pump but the pressure was good, ended up being vaccum lines, had some rotten hoses that were cracked and leaking. its never messed up since.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Thu Jan 22, 2004 5:55 am
Something often overlooked is the fuel line from the tank to the pump. It will sometimes get a small crack and suck air instead of fuel. If the body or hose gets twisted just right it will starve for fuel. And other times run fine.
stripped and just a memory!
PostPosted: Thu Jan 22, 2004 12:09 pm
:roll: I will go with the vacuum hoses. I have had a problem where the fuel pump gets clogged.
PostPosted: Thu Jan 22, 2004 9:56 pm
Federal emission trucks do have EGR valves and the thermo control switches as well as the air injection pump. One of the switches on the air cleaner controls the hot air intake damper valve, that thing that makes it suck air across outside of the exhaust manifold when its cold. I've had a couple of them leak on me.
The parts I'm really thinking here are anything with a vacuum line going to it. A vacuum leak really seems like the best answer to the whole set of symptoms, and its not uncommon on these trucks to find cracked/rotten hoses. Replace lines and try capping off things one at a time to make sure some valve or part isn't leaking too.
PostPosted: Fri Jan 23, 2004 7:17 am
You reminded me of a problem with a gasket on one of the places that gets supplied with the air. That was on my 77. I can't remember for the life of me where it was, but I think it was the carb gasket.
