It is currently Tue May 14, 2024 8:17 am
PostPosted: Fri Jun 17, 2022 6:31 pm
Hello all,
I have an 80 Chevy LUV that turns over but isn't igniting. Checked plugs and they weren't getting spark. I replaced the plugs, wires were already brand new, ignition coil, cap and rotor, and the points. The fuel pump had to be rewired directly to the ignition switch on account of the original fuel pump wire having no power. I'm running out of ideas on what could be the culprit... I am currently looking into the fuel pump/ignition relay being the issue but I can't find same part replacement any where.. Does anyone have a part number for a good replacement or substitute? Any help on getting her back on the road would be much appreciated.
