It is currently Sat Jun 13, 2026 10:03 am
 Post subject: 77 not starting up
PostPosted: Wed Mar 10, 2021 7:13 pm
When I turn the key I'm getting power but not starting up, it's not cranking any advice.
 Post subject: Re: 77 not starting up
PostPosted: Thu Mar 11, 2021 6:49 am
Battery charged? Might be power but not enough amps to turn the starter.
Check the battery connections. Make sure they are snug and corrosion free.
PostPosted: Thu Mar 11, 2021 9:16 pm
Maybe the clutch switch, if it has one. I don't think these trucks had them though. Is it an automatic? Could be the neutral safety switch.
PostPosted: Fri Mar 12, 2021 4:50 pm
I charge the battery no good does it seem to be the battery and it's manual
PostPosted: Fri Mar 12, 2021 5:54 pm
I was having intermittent starter issues, then it quit working completely. I took it out, removed the cover, and found the internal contacts were worn completely out. After replacing contacts, it was fine.
PostPosted: Sun Mar 14, 2021 10:24 pm
My Luv is manual and it has the clutch safety switch. Sometimes the wires come off the clutch pedal. I would also check your fuses. A process of elimination. After that you could pull the start and have a local auto supply test it.
PostPosted: Sun Mar 21, 2021 5:47 am
I got it running I got a whole new starter and it worked first try , I'll keep all the other options in mind if something happens
PostPosted: Sun Mar 21, 2021 6:09 am
Sweet! Way to go! What's next on the project list?
PostPosted: Tue Mar 23, 2021 10:59 am
Glad to hear that. 8)
Users browsing this forum: Google [Bot] and 46 guests
