It is currently Sun Jun 07, 2026 1:23 pm
PostPosted: Sun Mar 28, 2021 5:22 pm
My truck won't shift into any gear one through four. And I can feel something scratching when I try to shift into reverse I just change the transmission fluid. Any ideas to help narrow it down
PostPosted: Sun Mar 28, 2021 6:48 pm
Manual transmission?
Glenn
PostPosted: Sun Mar 28, 2021 7:26 pm
Sounds like a manual with the clutch not disengaging.
If it’s a hydraulic clutch, check the fluid in the reservoir. Could be the master or slave cylinder leaking. It takes regular brake fluid.
If it’s a cable clutch, watch the cable under the hood and verify it’s moving while someone presses the clutch.
If those check out, I’d suspect the throwout arm.
PostPosted: Wed Mar 31, 2021 9:16 am
Yup. What he said.
