It is currently Wed Jun 10, 2026 5:54 am
 Post subject: 4 speed transmission.
PostPosted: Mon Feb 01, 2021 3:58 pm
Hi guys, I am in really bad need for a rear yoke for the '77 LUV transmission. The shaft O.D. is 1.375" and it has 10 splines. Does anyone out there have one of these? I need to keep my work truck out there on the road. Thanks for looking......Don
PostPosted: Mon Feb 01, 2021 4:19 pm
Contact sqdeb@yahoo.com. Ask them for an Isuzu yoke with 10 (or maybe 11?) splines*. They shouldn't need any measurements. Spline count is the only thing that matters -- diameter will be right. I think this was the same spline count used on 1.8L and 1.9L applications.
As for whether it's 10 or 11, every yoke I've seen had one double-wide groove, so you'd see 10 actual splines in the yoke, but the output shaft had 11 splines. Same thing for 17-spline and 27-spline transmissions -- their yokes had one less spline.
PostPosted: Mon Feb 01, 2021 4:50 pm
Hey Joe, the address sqdeb@yahoo.com does not come up. Do I have it correct? Thank you.....Don
PostPosted: Mon Feb 01, 2021 4:52 pm
What do you mean "does not come up"? It's an email address. Sorry, I guess I could have just said that. ;)
