It is currently Wed Apr 24, 2024 3:38 pm
 Post subject: Weber Carb 32-36mm
PostPosted: Fri Oct 09, 2020 2:31 pm
Is anyone running a weber on their stock LUV? How do you like it? Was it hard to swap? I'm in the market for a new Hitachi for my '77 but maybe a weber is the better solution. Does their air cleaner fit under the hood? Thanks for the replies. Don
 Post subject: Re: Weber Carb 32-36mm
PostPosted: Sat Apr 10, 2021 12:26 pm
I have seen the Weber carb for about $300 new. they seem easy to put on. there are some videos on YouTube showing install. They are easier than the Hitachi to work on. I would be interested in the old HItachi if you go with the Weber. Dale (they do fit under the hood)
PostPosted: Tue Apr 20, 2021 8:33 am
I installed a Weber several years ago. No problem with the fit for both the intake and hood. It's still going strong.
