It is currently Sun Jun 21, 2026 2:39 pm
PostPosted: Sun Jul 19, 2020 1:00 am
hey folks. i just got my 76 running after 20 years of sitting and now i need to fix all the kinks.
when you turn the headlights on only the marker lights and the far right headlight come on. when you turn on the highbeams all 4 come on. what would be the cause of this?
also another kink with the headlights on only the left blinker works the right does nothing.
i just took the fuse box out and followed the repair article on here and put that all back in today so i dont think its the connectors unless its the fuses.
thanks!
1976 LUV, 0-60 eventually.............
put er in the ketchup!!!!
PostPosted: Mon Jul 20, 2020 4:19 am
I had this same issue a long time ago. I think I had a loose connection in the headlight switch.
PostPosted: Tue Jul 21, 2020 6:47 pm
Since the lights have their own fuses did you check to see if they have power
Users browsing this forum: Bing [Bot] and 30 guests
