It is currently Thu Jul 03, 2025 2:55 pm
PostPosted: Wed May 20, 2020 11:36 am
I need to replace the two bolts used to mount the alternator. How can I found out what they are and where to go to get replacements?
1978 Chevy LUV
Purchased Aug. 2014
Second owner
2006 Honda Shadow LX
Purchased July 2006
Original owner
"Not all those who wander are lost" - J.R.R. Tolkien
:twisted:
PostPosted: Thu May 21, 2020 6:25 pm
Hi, I'm pretty sure they are metric. Go to ace hardware and purchase 1-4 different size/diameter bolts that appear to be the correct diameter for the threaded hole. First thing to do is get the 'threads per inch' in metric. Then the diameter of the bolt in mm. Figure out the length you need and return to Ace to buy the actual bolts needed. Use a small nail or screwdriver to gauge the depth of the threaded hole. Make the new bolt length about 1/4 inch shorter including the alternator bracket depth. Return the others for refund. PS, keep the receipts and you'll probably have to make 2 trips......
PostPosted: Mon May 25, 2020 9:41 am
Thanks for the help!
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
