It is currently Mon Nov 30, 2020 11:22 pm
PostPosted: Fri Jan 03, 2020 2:20 pm
If someone has the time or a link what parts work with each other. Intakes to heads, heads to block, block to trans. I promise I'm searching. And I assure you that any help you can provide is greatly appreciated.
PostPosted: Fri Jan 03, 2020 5:02 pm
Will the 1.8 intake and exhaust fit on the 2.6?
PostPosted: Fri Jan 03, 2020 9:45 pm
viewtopic.php?f=6&t=20809&p=153352&hilit=Tumwatertaz#p153352
PostPosted: Fri Jan 03, 2020 9:46 pm
Check the links in that thread too...
PostPosted: Sat Jan 04, 2020 4:50 pm
Thanks! :D
