It is currently Fri May 22, 2026 8:31 pm
PostPosted: Sun Dec 22, 2019 7:18 pm
I'm working with a G180 engine that was dropped into a 72 Datsun 620 pickup.
I do not have any of the original wiring for the charging system and would like some help, The wiring diagram posted below wasn't much help.
I purchased this one to replace the bad 620 regulator:
https://www.amazon.com/Regulator-Altern ... =8-1-fkmr0
This one has: BLUE, Yellow, Black, Green, Red, White
Here is what I think right now:
White - B on the Alt. and Battery.
Blue - Charge Lamp.
Yellow - 'N' terminal on the alt. (small wire)
Red - 'F' terminal on the alt (small wire)
Green - Ignition.
Black - Ground
Last edited by michaelwherlihy on Sun Dec 22, 2019 9:16 pm, edited 2 times in total.
PostPosted: Sun Dec 22, 2019 7:33 pm
Here the wiring diagram. I’m not sure how much this helps.
http://www.luvtruck.com/PDF/Series3.pdf
