It is currently Wed Jun 10, 2026 12:25 am
 Post subject: Help!!!
PostPosted: Thu Jul 18, 2019 4:39 pm
So I have a 79 Chevy luv long bed I’ve replaced my alternator and battery and voltage regulator and I went through the wiring wiring but the battery is not charging but I can jump start the battery what could be the problem if anyone knows
 Post subject: Re: Help!!!
PostPosted: Fri Jul 19, 2019 4:09 pm
Have you checked each item with a voltage meter? Could have gotten a bad alternator.
PostPosted: Fri Aug 09, 2019 3:41 pm
Could be a bad ground between the frame and the engine/trans.
