It is currently Sat Jun 06, 2026 10:32 pm
PostPosted: Sat Jan 19, 2019 4:53 pm
My clutch pedal wobbles back and forth and really taking a good look found the mounting bracket piece is cracked. Any idea where to find a new one?
1978 Chevy LUV
Purchased Aug. 2014
Second owner
2006 Honda Shadow LX
Purchased July 2006
Original owner
"Not all those who wander are lost" - J.R.R. Tolkien
:twisted:
PostPosted: Sat Jan 19, 2019 6:07 pm
That is a common problem. You can remove it and have it repaired. Any used one you find will probably be headed in that same direction...
PostPosted: Sat Jan 19, 2019 8:26 pm
or worse, I had to repair mine twice in the 80's. Pull it out through the gauge cluster hole in the dash (remove gauge cluster), weld it, replace.
PostPosted: Sat Jan 19, 2019 10:24 pm
On my first Luv (79 4x4 in the 90's) I ended up having to weld a support bracket that went from the main bracket to the unsupported end of the pivot pin. Sort of an "L" that wrapped around the back of the pedal and made a form of truss to prevent all the torsion of the pedal being subjected to just the pin mount.
PostPosted: Sat Jan 19, 2019 11:24 pm
Yeah that's what I thought... I have my mechanic friend able to help with the repairs, and I think I will remove it next weekend. Thanks for the replies.
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
Users browsing this forum: No registered users and 60 guests
