It is currently Tue Apr 23, 2024 2:31 am
 Post subject: newer LUV frame
PostPosted: Wed Jan 09, 2019 9:40 am
I found an 81 LUV 4x4 and have a 2wd 74 that needs a lot of work and was wondering if the frames are the same and i could just slap my 74 on the 81 or if that would just end up being a nightmare? Thank you in advance
1980 4x4 LUV, 3 inch body lift, 4.56 gears, 31x12.50r15 Super Swamper IROKs, Weber Carb, Electronic distributor,
 Post subject: Re: newer LUV frame
PostPosted: Wed Jan 09, 2019 7:45 pm
I'm pretty sure they are quite different from each other. It could probably be done if you have good fab skills, but IDK for sure. I'm very uneducated on the 2nd gen LUV.
PostPosted: Thu Jan 10, 2019 6:39 am
And I'm more familiar with the 2nd gen, but too unfamiliar with the first gen to be of any help. But I'll bet oldestisuzuist would know the answers. ;)
