It is currently Sat Jun 06, 2026 10:31 pm
 Post subject: 17"X 8 wheels too big?
PostPosted: Sat Nov 03, 2018 10:26 am
2014 silverado wheels on craigslist, would they work on a stock 1982 luv? I notice the lug holes are bigger than mine, will that be a problem?
Thanks
PostPosted: Tue Dec 04, 2018 3:07 am
Thanks
I would think they will be too big. Have 15x8 with 205/70-15 Tires on, and it rubs, alot!
PostPosted: Tue Dec 04, 2018 9:23 am
Thanks
tr0jan - I'm not sure if you meant that your rims rub, or the tires. He didn't mention what size tire he's looking at. Also, he has an '82 (2nd generation), and I'm not quite sure if clearances are the same as your '75 (1st generation) LUV. I'm running 15x8 rims with no rubbing at all -- and I think my tires are 205-60 (not sure about the 205, but positive they're 60 series tires).
mojogoat - Sorry, I don't have a short answer to "would they work". But the size alone isn't a deal-breaker. Here's a post of a P'up with 18" rims (same body as your LUV). So you will need to make sure the center bores will fit. Second, the backset/offset needs to work. Some do, some don't. And if the rims don't give you clearance issues, it still can depend on the tires. One thing I've noticed is that the rear tires have way more fender clearance than the front.
Users browsing this forum: No registered users and 59 guests
