It is currently Thu Apr 18, 2024 9:25 pm
 Post subject: Door Hinge Repair
PostPosted: Sun Oct 21, 2018 12:01 pm
My lower driver's side door hinge had a pin break and it also bent the arm that that connects to the pin (see picture). Both parts of the hings already had a lot of play in them. I posted in the classifieds section to buy another one. I know the drivers side gets more use, so it will be hard to find one in good shape. What about having the existing one repaired? I may be able to get some of the pins from a passenger side hinge. Will this help, or will it still be a loose fit? What it be better long term to go to a machine shop? Thanks in advance.
 Post subject: Re: Door Hinge Repair
PostPosted: Mon Oct 22, 2018 12:45 pm
Pm sent Zane.
PostPosted: Sat Oct 27, 2018 1:49 pm
Without going out and looking at my truck, I think one of the hinges works on the other side when flipped over. Just can't remember which one, top or bottom.
PostPosted: Sat Nov 03, 2018 9:10 pm
The top ones you can flip, but the bottoms you can't. Looking into getting them rebuilt though. :D
PostPosted: Tue Nov 06, 2018 11:13 pm
:wink:
