It is currently Fri Feb 22, 2019 6:36 am
 Post subject: Lurchy drive
PostPosted: Thu Apr 26, 2018 4:31 pm
Hi all,
I have a 1980 chevy luv. I recently did an overhaul on the engine, replacing crank and connecting rod bearing, new rings, seals and gaskets. I had the webber tuned at a shop to pass DEQ. I've installed a new fuel pump. It is slightly higher pressure than recommended for the weber setup. I tried to install a fuel regulator from summit but it completely restricted flow. (So this could answer my own question.)
Other than what is mentioned, the truck is stock with all the smog/erg stuff still equipt.
I have been experiencing a surge/lurch during driving. Kind of like what you get when in reverse. Always while cruising at the middle top of a gear and it seems like it decided to do this once it got warmer.
Thank you for your time.
Pony | 1980 Chevy Luv
 Post subject: Re: Lurchy drive
PostPosted: Sat Apr 28, 2018 7:20 pm
Just a guess here but maybe a vacuum leak? As far as fuel pressur, I ran a return line to the tank so it's a fuel recirculating set up and the carb. just takes what it needs. Works good for me.
PostPosted: Tue May 08, 2018 5:22 pm
I will see about replacing the vacuum lines and write back about the effects.
Thanks
pony
Users browsing this forum: Bing [Bot] and 10 guests
