It is currently Sun Jun 07, 2026 1:03 am
 Post subject: GEN Light On At Start up
PostPosted: Fri Apr 20, 2018 10:13 am
Last two days the GEN light has come on for around three minutes after the first ignition of the day. The first day I examined the engine and did not notice anything out of place. I fired it up two more times and the light went out.
The next day (today), I fired it up, GEN light came on and I just let it warm up. After three minutes I revved the engine and it went out.
Yesterday it didn't come back on the rest of the day, and I have not started anymore times yet. Any ideas?
1978 Chevy LUV
Purchased Aug. 2014
Second owner
2006 Honda Shadow LX
Purchased July 2006
Original owner
"Not all those who wander are lost" - J.R.R. Tolkien
:twisted:
PostPosted: Fri Apr 20, 2018 6:19 pm
UPDATE: After work, I started the motor and no light came on. Drove home.
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
PostPosted: Fri Apr 20, 2018 8:38 pm
Maybe pop the top off the voltage regulator and check for moisture intrusion?
PostPosted: Sun Apr 22, 2018 12:10 pm
Could also be corrosion under a battery clamp, or corrosion under a ground wire. I would pull all your grounds, clean them up with a wire brush and reinstall with a little dielectric grease. It's also never a bad idea to clean up your battery connections.
