It is currently Wed Jun 19, 2019 5:15 am
PostPosted: Sun Apr 08, 2018 6:05 pm
My 79 luv was not having this oil circulation issue before I redid the head gasket. Now after I redid head oil doesn't seem to be flowing through engine. it makes a slight grinding noise(not clunking or piston slap) . I don't know how to figure this one out. Is it possible that when I had the oil pan off that the oil screen may have rusted up a bit? causing poor oil circulation. . I cannot seem to narrow down what could cause this. it did not have this issue before I started the rebuild. it seems highly unlikelythat the oil pump went out while it was sitting there. any advice or suggestions appreciated. thanks.
Luv from Hawaii
PostPosted: Mon Apr 09, 2018 10:22 pm
My first thought is make sure you used the correct head gasket. Possibly an oil galley has gotten plugged and not allowing oil from the block up into the head.
