It is currently Tue Jul 28, 2026 11:39 am
 Post subject: Raditaor isssue.
PostPosted: Thu Mar 08, 2018 5:53 pm
I need a new radiator cant seem to find em online. Are there any other vehicles that have compatable radiator I could swap thanks.
Luv from Hawaii
 Post subject: Re: Raditaor isssue.
PostPosted: Fri Mar 09, 2018 5:43 am
Without knowing what vehicle you need a radiator for it's impossible to answer your question.
PostPosted: Fri Mar 09, 2018 9:37 am
Yeah, 72-75 (I think, might be 74), 76-80, 81-82, gas or Diesel, auto or stick, A/C or not.
All factors.
PostPosted: Fri Mar 09, 2018 2:53 pm
72 is differant, can’t remember what the difference is. I gave a 72 radiator to a guy here and he said he made it work. Try to message Wildluvracing, he is parting out a few trucks.
PostPosted: Fri Mar 09, 2018 8:17 pm
Sorry about the misinformed post gentlemen I thought I put my truck info under my profile. its a 79 chevy luv 2wd automatic transmission.
Luv from Hawaii
PostPosted: Fri Mar 09, 2018 9:56 pm
From what I understand there are no "new" replacement radiators. The only way you're getting a replacement is to buy one off someone who no longer needs theirs. Of course, with yours being an automatic, you're in a whole different league due to needing the transmission cooler in the lower tank.
I have no idea if there ARE any other vehicles that carry a compatible one. I think you're either going to be modifying the radiator support to make a replacement fit, or running specialty hoses to make them line up. Or both.
PostPosted: Sat Mar 10, 2018 10:21 am
Could always do the speedway radiator the v8 guys use and run a separate transmission cooler.
PostPosted: Tue Mar 13, 2018 6:12 pm
I have a radiator out of a 75 with manual trans, if you are interested. It's in fair condition could use a pressure test and a few fins combed out but no major damage.
Users browsing this forum: No registered users and 95 guests
