It is currently Wed Apr 24, 2024 9:47 am
 Post subject: Weber linkage
PostPosted: Mon Feb 19, 2018 11:58 am
Looking for help on the setup you guys are using on your Weber carbs. I having an issue with the throttle cable hook up to the carb. I’m using the one from the hitachi and the rectangular slot has to much play, not a tight fit. The kit has one that requires you to cut the end off the cable. Not sure if I and up to cutting the end off. Any help would be appreciated.
76 LUV
