It is currently Fri Mar 22, 2019 11:02 pm
 Post subject: Head bolts
PostPosted: Fri Oct 13, 2017 8:38 am
Where is a good source for head bolts? The previous owner of my truck took the head off to rebuild it and I cannot find the bolts now.
 Post subject: Re: Head bolts
PostPosted: Fri Oct 13, 2017 10:03 am
http://headbolts.com/
PostPosted: Sat Oct 14, 2017 4:51 am
FYI the LUV/Isuzu G180Z 1.8L, G200Z 1.9L, 4ZC1 2.0L, 4ZD1 2.3L & 4ZE1 2.6L all use the same head bolts.
They are re-usable, so a used set is fine as long as the threads & the 10mm internal hex head are in good shape.
Lightly oil the bolts, the holes in the block should be clean & dry with no pooled oil in the bottom.
Users browsing this forum: Google [Bot] and 3 guests
