It is currently Sat Jun 06, 2026 10:31 pm
 Post subject: Oxygen sensor
PostPosted: Sun Sep 17, 2017 3:06 pm
Yesterday at a car show, I got introduced to an oxygen sensor system to be used on carbureted engines. The guy had a permanent mounted gauge in the cab and an o2 sensor in the exhaust header on a Model A Ford. He said he was able 'dial in' the proper carb setting [rich vs. lean] for the engine and was able to maintain the correct setting permanently via carb adjusting and jetting. Does anyone have one of these systems on their vehicle? I'm curious to know how you like it.
 Post subject: Re: Oxygen sensor
PostPosted: Sat Nov 18, 2017 6:50 pm
Wideband o2 sensor system. They can be bought for about $200 with gauge from diyautotune.com and many other places
If you want precise tuning there really is no better tool
And you can monitor air/fuel ratio any time to diagnose poor running conditions
PostPosted: Thu Dec 07, 2017 9:46 am
Thanks luvtheluv. I think I'll do it this spring. Got a 2.5 S10 to reassemble the engine first.
