It is currently Sat Jun 06, 2026 11:19 pm
PostPosted: Sun May 03, 2015 1:13 pm
I got my 72 luv with the gas tank out, bad freeze plugs and a bad radiator. So I now have new freeze plugs in and Im ready to put the gas tank back in but Im not sure what lines go where so if anybody can help me figure this out it would be greatly appreciated. Thanks guys
chevyluv@gmail.com Email me if you want
Back in the LUV game
For the love of the LUV!
PostPosted: Mon Aug 07, 2017 11:05 am
I'm having the same issue, except I just got a 74 that was lowered by previous owner and the gas tank was rolling around in the bed full of rust and I think they just removed some of the vacuum lines because its an aftermarket air filter and the manual says one of them goes from the gas tank to the air filter? Assuming this guy was only running a couple hoses and plugged the others? But I dont know which ones to hook up and which ones to plug...
-Karissa
-all you need is LUV
-Karissa
-All you need is LUV
PostPosted: Mon Aug 07, 2017 5:42 pm
Straight out of the parts manual
PostPosted: Wed Aug 09, 2017 7:44 am
I am going through the same thing right now as well and had some questions about it. When I picked my project up it had the carbon filter thing already removed and discarded, so where should I run the lines that were originally hooked up to it? or can I just cap them off and make sure there is a vent on the tank? Any advice on this would be helpful, Thanks!
PostPosted: Sat Aug 12, 2017 10:43 am
here's a couple of the gas tank lines on my 77 the way i think they go. BUT using the manual is the best way to be sure .
Users browsing this forum: No registered users and 67 guests
