It is currently Sun Jun 07, 2026 2:18 pm
 Post subject: Fuel pump cut off switch
PostPosted: Thu Dec 11, 2003 11:27 pm
Does anybody know where the fuel pump cut off switch is located on a 1980 chevy luv all stock 1.8L :?
PostPosted: Fri Dec 12, 2003 1:21 am
I didn't know there was one?
PostPosted: Fri Dec 12, 2003 2:30 am
there isnt a switch perse. What it is is a relay that interfaces whith the oil presure sending unit. If oil presure dropps too low then the motor cuts out. At least this is my understanding of the system. I would start whith the oil sending unit and make shure its good(does your OIL light come on at all?)
PostPosted: Fri Dec 12, 2003 3:38 am
My oil light doesnt come on, the reason I was asking about the fuel pump cut off switch is because when I was looking up parts for my luv it said that they had a fuel pump cut off switch for my truck so I just wanted too see if anybody knew anything about or knew where it was at. But I will look further into it :!:
PostPosted: Sun Dec 14, 2003 9:25 pm
OG Lifer
The fuel pump relay is mounted on the passenger side fender, under the hood, on a silver plate. The relay is mounted on the back side of the plate. I had hell with mine a while back. Finally got a new relay wired in.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Tue Dec 16, 2003 10:48 pm
to top it all off the relay is only energized when the key is in the START position or the alternator is supplying power. That prevents the fuel pump from pumping gas when the engine is not running.
PostPosted: Wed Dec 17, 2003 2:50 am
OG Lifer
That is correct. A ground to the relay is only supplied AFTER the key has been turned from off to start and returned to the run position. That is so messed up.
PostPosted: Wed Dec 17, 2003 4:09 am
no think its alot better than the ford inertia switch :roll:
I think its a safety feature that was head of its time, if the luv rolls or is in a bad wrekc and the motor stalls, there is no risk of gas dumping all over the place, i think thats good thought.
PostPosted: Wed Dec 17, 2003 5:56 am
I don't have a clue what this topic is about.....all I see is an avitar 8O
03Cobra
PostPosted: Wed Dec 17, 2003 6:51 am
who cares, its a vary nice avatar isnt it? :lol:
oh yeah, #900 8)
PostPosted: Wed Dec 17, 2003 2:33 pm
Yes it is 8O
PostPosted: Wed Dec 17, 2003 3:50 pm
That's what I want for Christmas!
Resident lurker
PostPosted: Thu Dec 18, 2003 8:04 am
Where do i sign up?! :lol: :lol: :lol:
PostPosted: Thu Dec 18, 2003 9:24 am
I'd also like that for X-mas :lol: ......But the wife would probably get mad. :cry: :cry: :cry:
 Post subject: wired wrong
PostPosted: Sat Dec 20, 2003 8:59 pm
Ahile back I had the oil and temp gauge switched. When I truend on the truck the temp guage went all the way to hot and the back down, and the the oil light slowlyh got bright. ha :roll:
PostPosted: Fri Jan 02, 2004 1:34 pm
The only one that I am aware of is a float that pops in so that if it flips over it cuts the gas off. Never heard of another one.
