It is currently Thu Jun 25, 2026 6:50 pm
 Post subject: Headliner Removal
PostPosted: Tue Jan 31, 2017 5:39 pm
Has anyone removed a headliner successfully? If so, could you explain how it comes out? Thanks
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
 Post subject: Re: Headliner Removal
PostPosted: Tue Jan 31, 2017 7:48 pm
Yes, had to take mine out for the shop to use it as a template for the new one. The front and back windows will have to come out, then remove the pinch moulding over the doors, sunvisors, rearview mirror and the plastic trim towards the back. There are 2 or 3 rods (cant remember, its been almost 30 years since I took mine out) that are sewn inside the headliner that go from side to side, there are in holes on each side the rods sit in and you should be able to slide them one direction and have the other side come out of the hole (might have to bend them a little).
A few pics that might help are here.
http://www.chevymetalhead.net/trucks/luv/interior.htm
PostPosted: Wed Feb 01, 2017 2:20 pm
Thanks TITLED. I will look into it.
Tucson, AZ
Users browsing this forum: No registered users and 55 guests
