It is currently Thu Jun 25, 2026 1:45 pm
 Post subject: 81 luv camber issue.
PostPosted: Wed Jan 04, 2017 12:17 pm
Not sure if I've got worn out suspension parts somewhere, or what. The wheels seem to have tilted more after I upped the tire size/rim width.. Ideas? Suggestions? Thanks in advance!
1981 Chevy Luv 4x4 Mikado Longbed.
Bone Stock power train, Fat Mud Terrains, And Tweaked out T-bars ;)
Ballin' on a budget! :evil:
 Post subject: Re: 81 luv camber issue.
PostPosted: Wed Jan 04, 2017 4:26 pm
Not too sure here, but my guess would be to take it to a shop and have it aligned.
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
PostPosted: Wed Jan 04, 2017 4:30 pm
I know nuthin about camber, but there was a recent thread on the P'up site that might be helpful.
http://www.isuzupup.com/viewtopic.php?f=18&t=24218
But if it were mine, I'd have to just take Jacobbarnes1's advice and take the truck to a professional. ;)
PostPosted: Fri Jan 06, 2017 11:24 am
Mine look similar after adjusting ride height a bit. The alignment is easily tweaked by tire size or ride height changes. Wider rims mean the base contact point has likely been shifted outward causing your camber change.
Even when you get new tires of the same size youre supposed to get an alignment to keep everything just right.
Shouldnt be a big deal. 40-45 for a front end alignment near me.
