It is currently Thu Jun 25, 2026 11:34 am
 Post subject: Engine Question
PostPosted: Mon Nov 28, 2016 11:27 am
This could be a dumb question but, I was wondering if someone could explain why my cylinder head has g200 on it and my engine block has g180 on it?
1979 Base 4x4
 Post subject: Re: Engine Question
PostPosted: Mon Nov 28, 2016 11:42 am
The head has been swapped at some point...
PostPosted: Tue Nov 29, 2016 7:15 am
A G200 head on a G180 block lowers the compression ratio. If your engine seems to lack power this could be a partial cause.
PostPosted: Tue Nov 29, 2016 12:14 pm
I see, thanks for the info! I have been having trouble getting it started, so I can't really talk to it's performance.
But I have another question about the engine that y'all might be able to explain to me. My 4th cylinder had a non fouler installed. From what I have read, it doesn't sound like a good thing, but a temporary fix. Can someone explain the potential issues that my engine may have?
Thanks for your time and help :D
1979 Base 4x4
PostPosted: Fri Dec 02, 2016 4:53 pm
Most likely bad rings on #4 or possibably valve steam seals.
PostPosted: Fri Dec 02, 2016 5:08 pm
Is that something that will cause damage to the engine if I don't fix it immediately?
1979 Base 4x4
PostPosted: Fri Dec 02, 2016 5:17 pm
More then likely it will just continue to burn oil and foul the plug.
Users browsing this forum: Google [Bot] and 83 guests
