It is currently Fri Apr 19, 2024 2:02 am
PostPosted: Mon Nov 21, 2016 1:43 pm
Some of you may have seen my previous posts, but long story short is I took my engine out to replace the rear main seal and the clutch. Now I have it back in and I've been having trouble starting it. I currently getting inconsistent sparking (i.e. weak sparking, not sparking, or sparking normally).
I have replaced the ignition coil, distributor cap, distributor rotor, break points, condenser, spark plugs, and wires.
I don't know much about the timing, but may have messed it up by turning the distributor when reinstalling it. I also am not 100 certain about the wires are in the right order.
Can someone help?
1979 Base 4x4
PostPosted: Mon Nov 21, 2016 3:17 pm
I would check your grounds (battery to block, battery/block to frame)
PostPosted: Sat Jun 10, 2017 10:57 am
Fire order is 1,3, 4, 2 rotor on 1.8 is counter clock turn.
PostPosted: Fri Jun 16, 2017 11:13 am
what I did to get mine to run is put 4 up to tdc and where the rotor is at is #4 straight across from it is 1 and 2 7 3 are the other 2
use the previous firing order post to help you out too.
