It is currently Thu Jun 25, 2026 7:27 pm
 Post subject: Weber swap help
PostPosted: Mon Oct 10, 2016 10:12 am
Guys, is this everything I need to switch carbs? Price good or bad.
Also a bit confused on exactly what I need to go electronic on the distributor, or will the carb switch be sufficient. Thanks to everyone for your kind advice.
CHEVROLET LUV 72-83 WEBER 32/36 DGEV ELECTRIC CHOKE CARBURETOR CONVERSION NEW https://www.amazon.com/dp/B00SXLCAX8/re ... -xbVZXEBZQ
 Post subject: Re: Weber swap help
PostPosted: Mon Oct 10, 2016 8:03 pm
I am running the weber 32/36 carb it was about the same price straight from weber and I am running the pertronix
electronic ignition its a easy swap pull your points and condenser drop the pertronix in bolt it down run your wires and your done
you dont need the balance resistor either.
PostPosted: Tue Oct 11, 2016 6:44 am
Thanks so much.
PostPosted: Sat Oct 15, 2016 11:34 am
That's also the same carburetor im using and I believe I paid about as much for it. Best thing I ever bought for the truck.
Overkill is underrated!
PostPosted: Wed Oct 19, 2016 10:55 am
Are there any model #'S on these weber 32/36 carbs.....I'm trying to confirm which model this guy has to be sure its a 32/36 carb
PostPosted: Wed Oct 19, 2016 11:52 am
I just called Weber, told him I wanted the 32/36 kit for 79, 1.8.
He said if you replaced the fuel pump, I needed fuel pressure regulator.
Code Item Qty Price Grand Total
WK663 WK663 - 32/36 DGEV WEBER Chevrolet, Ford, Isuzu, Mazda, Nissan, Toyota Carburetor Complete Carb Conversion Kit
1 $239.95 $239.95
12-804 Fuel Pressure Regulator
1 $39.95 $39.95
Subtotal: $279.90
Tax: $0.00
Shipping Cost: $0.00
Grand Total: $279.90
Users browsing this forum: No registered users and 67 guests
