It is currently Fri Jun 12, 2026 7:36 pm
PostPosted: Fri Sep 30, 2016 8:19 am
New to this forum so don't know if this has been discussed: I have a 4x4 '81 LUV Mikado, stock except T-bar lifted on 30x9.5/15's. Most of the front end moving parts - rubber bushings and joints like cv axles and tie rod ends - look worn and probably should be replaced before getting her on the road again. Found tie rods and bushings on rockauto, but having a hard time finding the IFS cv axles anywhere. Anyone know if the axles from an 80's s10 or P'up will swap over and what years? How about longer axles and swing arms for a higher lift? Or should I just do a straight axle swap and forget IFS? Also, are their any mods I absolutely SHOULD do, such as power steering or EFI instead of the stock carb? Haven't driven it on the road much yet, so I don't really know how she rides right now. Any help would be greatly appreciated. Thanks!
PostPosted: Fri Sep 30, 2016 2:58 pm
The P'up of the same year is exactly the same truck, aside from trim. I think front end parts stayed the same through '83. There's not much on an S10 that will swap over.
PostPosted: Fri Sep 30, 2016 3:33 pm
I'm having trouble finding CV axles, too, for a '79. The right outer CV joint needs a new bearing-thingy (pics below). I'd appreciate any ideas on how to get one!
As for mods, ShLUVain, i replaced my stock hitachi carb with a Weber 32/36. It was pretty easy and works great! A little more power and way simpler... got to cut out all the smog crap. Just as long as you don't have emissions laws...
File comment: missing bearing from right CV joint
File comment: left CV joint: all there!
PostPosted: Fri Sep 30, 2016 4:14 pm
Good luck on the front cv joints. I've had 6 different companies send axles listed as compatible. None were.
I've been searching for over a year. I wish I had better news.
PostPosted: Fri Sep 30, 2016 4:47 pm
I have a contact who was an Isuzu mechanic for years. He still has access to Isuzu parts--often parts that the dealers wouldn't keep in stock. I'll check with him. Gene, is yours an '81 as well?
PostPosted: Fri Sep 30, 2016 5:38 pm
79. Mines 4x4. Mines working now but I could use front, left and right
PostPosted: Fri Sep 30, 2016 5:43 pm
My friend is a former Isuzu guy. If the part for the '79 is the same as the one for the '81, he may be able to get it.
PostPosted: Mon Oct 03, 2016 12:16 pm
Pm sent about Cv axles War Pony.
PostPosted: Mon Oct 03, 2016 12:22 pm
Here's the update I got from my source:
Quote:
HI JACK, NOTHING AT ALL ON THOSE , THEY HAVE BEEN DISCONTINUED A LONG TIME AGO , AND ABOUT THE ONLY THING YOU CAN DO IS HAVE THEM REBUILT , THE ONLY PLACE THAT I KNOW THAT WILL REBUILD THOSE IS IN ALITTLE TOWN ABOUT 45 MIN FROM HERE AND THE LAST ONES I HAD DONE WAS 200.00 MY COST.
Sorry it's bad news! :(
PostPosted: Mon Oct 03, 2016 3:58 pm
I'll gladly pay that when mine wear completely out.
