Does my wiring seem to be ok? I got new coil and Ballast Resistor as having issues with starting the truck after the new Weber 32/36. I tested the wiring with my multi-meter and I am getting 12V at all 4 points (2 points on coil and 2 points on ballast). I keep the red wire on the battery from MM and the black wire to each point and I get 12V is that right? seems like the Positive (+) on the coil should be 0 with the red wire from MM touching the + on battery, but I get 12V thinking that the Coil + is being grounded. Can any one clarify?
thanks
| Attachments: |
_________________ -1978 LUVLEE Stepside (4G63 inside)
