It is currently Sat Jun 06, 2026 10:32 pm
 Post subject: Misfireing headach
PostPosted: Sat Jul 09, 2016 4:34 pm
So my 1.8 in my 81' is missing but ONLY when not under load. So revs like a champ but once it gets to rpm it misses again, and misses at idle. Narrowed it down to cylinder no 1. Diagnostics: Compression test, good; Replaced spark plugs, wires, and cap and rotor, replaced coil. Couldn't find an intake leak but still replaced intake manifold gaskets and carb gaskets anyway. Vacuum hoses appear to be good and are relatively new. I'm stumped the only things left are the solid state igniter or the distributor. Opinions?
"but still try, for who knows what is possible..."- Micheal Faraday.
'81 white Luv Mikado 4x4 with nearly all the options. Granddad bought it new.
 Post subject: Re: Misfireing headach
PostPosted: Sun Jul 10, 2016 3:10 pm
check your timing
PostPosted: Sun Jul 10, 2016 4:23 pm
timeing is correct as far as i'm aware.
Users browsing this forum: No registered users and 59 guests
