 Post subject: Hood frame gap
PostPosted: Thu Jan 14, 2016 3:57 pm
Is this the way it's supposed to be? There is a gap between the sheet metal and the support frame work, and along the way there seems to be several rubber disc's pushed in there to provide support.
http://i1020.photobucket.com/albums/af3 ... fmviuz.jpg
When the only tool you have is a hammer, everything looks like a nail.
 Post subject: Re: Hood frame gap
PostPosted: Thu Jan 14, 2016 4:54 pm
That is normal, there used to be some material that filled the gap a various points along the framework but they rot away. I replaced some on a louvered hood I used to have with some automotive carpet I cut into small squares and slipped into the gaps.
You can see some of the rotted out material in your pic, looks like blobs now.
PostPosted: Thu Jan 14, 2016 9:26 pm
It looks like the gap is different on one side compared to the other, I think it is bent a little making the gap wider, but I can see the glop you're talking about. Looks like the stuff they use to seal roof leaks!
PostPosted: Thu Jan 14, 2016 11:32 pm
I would say yes its common to have gaps
I think originally there was a gap on the hoods but i get the feeling over the years the sun beating down on them
the material that is in there has softened up and pulled apart some i picked up ahood today where its all separated.
if anyone know what this stuff is.....I'd like to see about getting more and redoing those spots on this hood
