It is currently Sun Jun 07, 2026 3:47 am
PostPosted: Mon Nov 30, 2015 8:10 pm
I have a 1979 Chevy luv Mikado. It stalls when I accelerate, if I pump the gas I can get lucky and it will keep going. It happens often but not all the time. I have replaced the alternator, fuel pump , fuel filter, new fuel lines, gas tank is clean, new spark plug wires. New carberator. New distributor cap, adjusted the points and timing. I am out of ideas, can it be a battery shortage? Sometimes when I'm real unlucky it won't start and I have to get a jump
PostPosted: Thu Dec 10, 2015 12:53 pm
Check the distributor cap. There's a little metal thing held in by a spring on the inside of the cap under where the coil wire plugs into it
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
PostPosted: Thu Dec 10, 2015 2:55 pm
You've replaced all those items after it started having problems?
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Sun Dec 13, 2015 7:54 pm
Stock carb?
PostPosted: Fri Dec 18, 2015 9:55 am
Did you pull the vacuum line off the dist and plug it when you set the timing?
PostPosted: Sun Dec 20, 2015 10:51 am
I am having similar problems.
idles fine, drives fine. full throttle though a bit of a problem.
feels like full power is cut, and car actually de-accelerates.
I bent the tab for the secondaries. and was able to activate it when car was idling.
Saw that fuel was coming out of venturies. Not sure if sufficient. Engine reved up.
So I am now thinking that the ignition system not strong enough.
