PostPosted: Wed Nov 25, 2015 11:53 am
I'm going to change all the fluids, drain the fuel, change all filters, points, plugs, wires etc.
We're the wires and plugs NGK or Denzo?
I foot to mention it's been sitting 10 years.
Did I miss anything? The oil was clean and the tank was dry. I put a gallon of gas and Start on treatment.
It started fine, but that was as far as I went.
Suggestions?
Thanks
PostPosted: Wed Nov 25, 2015 4:59 pm
Not sure the brand of plugs and wires matters but i have ways favored ngk plugs in my cars and dirtbikes.
I recommend replacing the fuel filter and adding a second one before the carb in case there is any crap in the fuel lines from sitting so long.
Maybe run a can of seafoam in the oil before you drain it and some in the gas. Would need some more gas unless you measure out a bit of seafoam it has the mix with gas ratio on the bottle
PostPosted: Thu Nov 26, 2015 10:18 am
I would put gas in it and drive it around. Stay ready for a problem or two. Fuel filter might plug up if the gas tank is rusty. After 50/100 miles, and all is well, change the oil and coolant. It should be fine.
Oh, keep an eye out for leaks. The biggest harm letting a vehicle sit a long time is seals dry out and leak when you get it going again.
PostPosted: Thu Nov 26, 2015 10:23 am
When I bought my truck it sat for a good year. My gas tank has some rust in it. I ended up having a shop clean it out and seal the inside. I use 2 gas filters. One in the stock location on frame by the gas tank, and the second up by the carb.
I had to also replace the rear brake wheel cylinders. The front calipers worked for a short term, but I ended up replace those as well.
PostPosted: Sun Dec 06, 2015 3:53 pm
1: Next question: Inside rear view mirror is cracked, as in all the way through. Can a repair shop replace the mirror in the existing frame?
I guess finding another complete mirror is impossible?
2: Found a Chiltons manual. It recommends 91 plus octane. Mechanic says no ethanol. I guess I was wrong all these years.
Thanks as always.
PostPosted: Sun Dec 06, 2015 10:05 pm
Thanks as always.
That is 91 research octane, which equals 87 octane pump unleaded. Lots of foreign-built autos use the research method for fuel requirements, my '03 Tacoma lists the same 91 octane requirement, but it's research octane, not pump octane.
PostPosted: Sun Dec 06, 2015 11:08 pm
Research octane + method octane / 2 = pump octane
Either way, regular 87 octane is fine. 85 is fine if you live in elevated areas like Colorado.
PostPosted: Mon Dec 07, 2015 12:38 pm
in my opinion, If this was sitting sitting 10 yrs ..1st thing .I'd do is drain that tank and see about getting the rust/ crude
inside ...especially if it was dry as you'll push all that (that may be inside up to your carb and only cause problems/
