cadams02 wrote:
Does any one have a picture of where the stock evap lines come out of the firewall. Im getting ready to install a/c in my truck that didnt come with it and needing to cut the holes in the firewall.
cadams02 wrote:
Mine is a 77. I already have all the stock a/c stuff for under the dash.
I'm assuming this means you have the evaporator box, which should connect to your existing heater box. If so, that should dictate where you cut the holes, shouldn't it? As for the a/c lines in the cab, you can have them custom made (soft lines) and use any generic condenser that fits. Do you have a compressor and bracket?
I have a hard line from a 2nd gen, and I think it should fit your rig--but I can't think of any possible way to ship it without damage.
JoeIsuzu@IsuzuPup.comIsuzuPup.com
