I'm in the process of putting newer LUV disc brakes on the front of my 75. Got everything done, and have clean fluid with no air at all four corners. Brake pedal still goes to the floor! I replaced the master cylinder with the one that is supposed to be on the 75, but the tutorial on this site says I need one for the 76 that came with discs. I did search this site and read several posts before posting this question. I looked on NAPAs website, and they list the same master cylinder for the 75, 76, 77, 78. The 1979 I have has the ports on the other side and has a proportioning valve near the master. My question is, what master cylinder do I need to make this work properly?
