It is currently Sun Jun 07, 2026 3:27 am
 Post subject: generator light
PostPosted: Thu Jul 02, 2015 12:21 pm
79 luv when you turn off the ignition the generator light comes on and the vent fan continues to run, radio, gauges etc are off
 Post subject: Re: generator light
PostPosted: Thu Jul 02, 2015 3:18 pm
A couple guesses. Could be the voltage regulator, try to disconnect it and see if everything goes off. My best guess is the ignition switch, try to disconnect it and see what happens.
PostPosted: Tue Jul 14, 2015 3:01 pm
Tried voltage regulator no luck will try ignition switch
PostPosted: Tue Jul 14, 2015 3:21 pm
The later trucks have a "charge relay" that ONLY allows the fan to run when the battery is being charged. If this relay were to get stuck in closed position, I assume the fan would continue to run. It's worth a look. On the later trucks, it's under the hood on the driver's side inner fender.
Users browsing this forum: Baidu [Spider] and 39 guests
