PostPosted: Wed Jul 01, 2015 8:24 pm
Hi, I have a 1980 4x4 LUV. My radiator is toast and the local radiator shop says they can't do anything with mine. So since i'd rather have an aluminum Radiator, I'm gonna buy one that works with the truck and fits the opening and build mounts for it. So I was wondering if anyone has done this or if anyone has any certain brand that is good or any good info that I could use would be appreciated.
I also wanna do an electric fan, new to this kinda stuff so I would like to know which ones would work well with the LUV, or any certain brand, basically as much info as i can get about doing an electric fan. Thank you
1980 4x4 LUV, 3 inch body lift, 4.56 gears, 31x12.50r15 Super Swamper IROKs, Weber Carb, Electronic distributor,
PostPosted: Thu Jul 02, 2015 12:06 am
I had Dillon radiator fab one for me. It is a Northern radiator that he did a divorced filler neck on. Your radiator shop could probably do the same thing...
viewtopic.php?f=33&t=28778&start=20
