It is currently Sun Jun 07, 2026 12:59 am
 Post subject: Upgrading fuse boxes
PostPosted: Wed May 27, 2015 11:44 pm
If i upgrade my stock fuse box on my 80' Luv, for a HELLA H84960091 or one of these... http://m.summitracing.com/parts/SUM-900173/ how do i know where my wire cables go clipped onto? Does anyone know a guide or method for doing this? Maybe even a video? Id appreciate it alot, Thanks!
 Post subject: Re: Upgrading fuse boxes
PostPosted: Wed May 27, 2015 11:49 pm
One each side of the box is the spade for the wiring terminal. Pull one wire from the old fuse box at a time on each side, keeping them in the correct order down each side, then add the same amp spade fuse as the old round fuse you are replacing...
