It is currently Sun Jun 07, 2026 2:29 am
 Post subject: Upgrading fuse boxes
PostPosted: Wed May 27, 2015 11:44 pm
If i upgrade my stock fuse box on my 80' Luv, for a HELLA H84960091 or one of these... http://m.summitracing.com/parts/SUM-900173/ how do i know where my wire cables go clipped onto? Does anyone know a guide or method for doing this? Maybe even a video? Id appreciate it alot, Thanks!
 Post subject: Re: Upgrading fuse boxes
PostPosted: Wed May 27, 2015 11:49 pm
One each side of the box is the spade for the wiring terminal. Pull one wire from the old fuse box at a time on each side, keeping them in the correct order down each side, then add the same amp spade fuse as the old round fuse you are replacing...
Users browsing this forum: Baidu [Spider] and 47 guests
