It is currently Sun Jun 07, 2026 2:28 am
PostPosted: Sun Mar 08, 2015 6:48 pm
So I have a 79 Chevy luv. 1.8 mikado with 32/36 weber. I took it to cedarville, CA and when I was coming back it started to stall. It got worst As time went on. I had junk mechanics install the carb and adjust the valves. Anyways now it stalls,backfires pops and a loud whine at higher rpms intermittently. Any ideas?
1979 Chevy luv Mikado 1.8 4 speed 4x4
PostPosted: Sun Mar 08, 2015 9:07 pm
They adjusted the rockers you mean? The stalling and popping could be it taking in air from the mounting plate for the carb. Did they use a gasket anywhere in there? Not sure what the whine could be. I'd probably start looking at vacuum lines... Such as the vacuum advance
Hannah - '79 4WD, 32/36 Weber, and a Pacesetter header. :D
PostPosted: Sun Mar 08, 2015 9:11 pm
Sounds like having a look at the timing chain and tensioner might be a worth while move.
Users browsing this forum: Baidu [Spider] and 44 guests
