It is currently Sun Jun 07, 2026 2:29 am
PostPosted: Wed Mar 11, 2015 12:54 pm
Should it be pressure primed or can I run a priming tool where the distributer goes?
PostPosted: Wed Mar 11, 2015 2:44 pm
I always just run pump through Distributer hole with a old honda push rod and high speed on drill till oil light goes off.
PostPosted: Thu Mar 12, 2015 9:23 pm
You can pull the coil wire and use the starter to prime it too if you don't have the tool.
When I crank my 61 Mercedes up after it sits for a few months I can tell when the oil primes because it has an oil pressure gauge and the cranking slows down a lot when the pressure comes up. It takes a long time to start because it doesn't run much. You can use your starter too but don't crank for more than 45 sec. The battery terminals get hot and the starter can burn out.
PostPosted: Thu Mar 12, 2015 10:21 pm
If you are going to prime by the starter I recomend pulling your spark plugs.
Users browsing this forum: Baidu [Spider] and 45 guests
