It is currently Sun Jun 07, 2026 2:29 am
 Post subject: Weber air filter help?
PostPosted: Tue Feb 17, 2015 7:26 pm
Hey all, I need to replace the old (original) air filter that came with my 32/36.
Does anyone know the part # for a fram or stp or even K&N filter that will fit the standard square Weber air cleaner?
I would rather not drop $20 on one from redline, but the parts stores can't help me since they only have lookups for stock filters. Thanks!!
Image1980 4x4, 3" body lift, G180/G180 head, Pacesetter header, Offenhauser Dual Port Intake, Weber 32/36, Electronic Ignition, Glasspack & a Smokestack.
PostPosted: Wed Feb 18, 2015 10:21 am
http://www.webercarbsdirect.com/DGV_DGE ... S_s/70.htm
:D
Hannah - '79 4WD, 32/36 Weber, and a Pacesetter header. :D
PostPosted: Wed Feb 18, 2015 11:48 am
http://www.ebay.com/itm/Omix-Ada-17704- ... 6e&vxp=mtr
This is the cheapest I can find for a Weber filter, includes shipping unlike the previous link. These private-label filters are for the same 32/36 Weber when it's mounted on a Jeep.
I tried all Weber part numbers I could find in the cross reference sites for Fram, WIX & K&N, none returns a match. I tried the size/shape search for K&N, again no match.
You may have to just continue to buy Weber-specific filters.
OR- I bought an adapter (about $37) to mate any standard 5-1/8" neck after-market air filter housing to the Weber carb, then I can use any brand filter that fits the housing. There's a good bit of initial expense with the adapter and air filter & housing but replacement filters are available anywhere & relatively cheap.
PostPosted: Thu Feb 19, 2015 4:46 pm
Thanks. That was what I was finding, that nothing really fits other than the weber specific filter. The adaptor/air cleaner isn't much more than a replacement filter, so I may just go that route.
I appreciate the help. :)
Users browsing this forum: Baidu [Spider] and 45 guests
