It is currently Mon Jun 08, 2026 12:59 am
 Post subject: HELP!!!
PostPosted: Sat Jan 24, 2015 9:54 am
I am wanting to convert my drum brakes to disc. I was just told I could use everything from a 1980-1982 Toyota pickup EXCEPT the lower control arm, and would have to redrill the tie rod bracket. Do you guys know anything about this?
 Post subject: Re: HELP!!!
PostPosted: Sat Jan 24, 2015 10:11 am
Never seen it done.
PostPosted: Sat Jan 24, 2015 11:46 am
Worst. Subject line. Ever. :(
I can't help with the question, but I PROMISE it would get better response with a descriptive subject, like "Drum to disc conversion help needed" or something similar.
PostPosted: Sat Jan 24, 2015 3:50 pm
It's been done, but it is not as easy as you'd want to believe.
viewtopic.php?f=7&t=13497
PostPosted: Sat Jan 24, 2015 3:53 pm
Have you checked into getting your stock ones re-drilled? I mentioned that in your other thread. This guy will do it for $160. viewtopic.php?f=8&t=27266
Here's a link to your other thread with my reply.
viewtopic.php?f=5&t=29120&p=212104
