 Post subject: Fuel filter
PostPosted: Tue Dec 09, 2014 4:29 pm
Where is my fuel filter located in my 1980 Chevy Luv
 Post subject: Re: Fuel filter
PostPosted: Thu Dec 11, 2014 5:55 pm
Kneel down just behind the driver's side door and look up under the bed. Its clipped to the body and plainly visible.
There is also one inside the carb I think.
PostPosted: Tue Dec 23, 2014 5:10 pm
I"ve got an 80 Luv 4x4. I have my stock gas filter, but I also installed a secondary gas filter up by the carburetor. I like the idea of a little more protection to the carb, and it's a good check point to see fuels going to the carb.
PostPosted: Fri Jan 02, 2015 12:47 am
I only see an electric fuel pump clipped on to the frame thats about it, could it be that? Maybe its an electric fuel pump with a fuel filter all in one?
PostPosted: Fri Jan 02, 2015 8:42 am
Here is a pic of my truck, look at the front of the tank by the cab in between the frame rail and tank, mine is square (not sure why I got a square one) and is should be sitting inside that round clip just in front of the bed mount on top of the frame.
PostPosted: Sat Jan 03, 2015 9:42 am
It should be spliced into the supply line from the tank just a short distance from the frame mounted fuel pump. Start at the pump and trace towards the tank. A stock pump has a filter screen, but it's not serviceable, you must have an in-line filter before the pump or the pump will fail, they don't like dirty fuel.
