It is currently Sun Jun 07, 2026 2:27 am
PostPosted: Sat Nov 01, 2014 8:42 am
I'm stuck. My luv is having problems and I'm not sure what the deal is. My generator light is on and I checked what it's charging it and its only 12 volts, thays with a new alternator. The old one was charging at the same rate. It'll start and run temporarily but then die. I checked the fuses they are all fine. Any tips on what to do and look at would be greatly appreciated thanks.
PostPosted: Sat Nov 01, 2014 8:43 am
Voltage regulator
PostPosted: Sat Nov 01, 2014 11:35 am
When the alternator stops charging, the fuel pump stops and engine dies. Normal behavior. Yes possible voltage regulator failure. Temporaily unplug the regulator and engine should run.
PostPosted: Sat Nov 01, 2014 4:00 pm
Where is the voltage regulator?
PostPosted: Sat Nov 01, 2014 8:19 pm
Drivers side fender well, 2 10mm headed bolts holding it down with a bunch of wires coming out of it.
PostPosted: Mon Nov 03, 2014 12:14 pm
Be sure to do the fuse box fix if you have electrical gremlins.
