It is currently Sun Jun 07, 2026 11:51 pm
 Post subject: Interchangeable Trannys?
PostPosted: Sat Nov 29, 2003 12:55 am
Can anyone tell me what years are interchangeable for trannys. Some say 72-75 then 76-78...then 79-82. Others say 72-77 and 78-82. :o Any help would be great. Is it the same with engines??? 8O
PostPosted: Mon Dec 01, 2003 1:01 pm
I dont think that you can put an 82 tranny into a 78. the are two completely diferent series and body styles. but from 72 up to, i think 75 the engine is the same, then from 76 to 80 the engines are the same.
Currently no more luv's... But in search of one!
PostPosted: Mon Dec 01, 2003 1:08 pm
i know that on 4x4, 80 and 81 have the same trans, and thats 2 different body styles, not sure about 2wd
PostPosted: Mon Dec 01, 2003 1:26 pm
Well, looking at all of the history on the forum, it looks like the 72-75 will interchange because the starter is on the driver side. 76 on up has the starter on the passenger side. The 78 they went to a cable clutch system so in order to put a 78 tranny on a 76 body I need new linkage and a modified mount where it exits the firewall. Most people are saying that I should get rid of the slave cylinder and go with cable.....any thoughts??
PostPosted: Mon Dec 01, 2003 1:27 pm
i would go with the cable.
PostPosted: Tue Dec 09, 2003 4:34 am
I've never replaced a clutch cable on my 79. I've rebuilt the slave cylinder three time and replaced the clutch master cylinder twice on my 77. I only rebuilt the slave cyl on my 76 once, but I only drove it about a year before it got hit by a bridge. Two words: GO CABLE.
PostPosted: Fri Jan 02, 2004 12:45 pm
I am not getting information out of the book on the 72-74's, but I know when I push the clutch pedal it goes to the floor effortlessly.
Did they have the cable or the hydro?
